[postgis-devel] [PostGIS] #576: 3d distance functions
PostGIS trac at osgeo.org
Tue Aug 24 06:34:31 PDT 2010
 Reporter:  nicklas      |       Owner:  nicklas
     Type:  enhancement  |      Status:  assigned
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Changes (by bitner):
 * cc: bitner (added)
Comment:
 Further 3D measurements without resorting to using linear referencing to
 extract closest points etc would be awesome.  As to index usage, the 3D
 distance is always going to be longer than 2D case, so the same BOX2D
 expansion will still be valid (just less selective). The following should
 still be valid, no?
 CREATE OR REPLACE FUNCTION public.st_dwithin(geometry, geometry, double
 precision)
   RETURNS boolean AS
 'SELECT $1 && ST_Expand($2,$3) AND $2 && ST_Expand($1,$3) AND
 _ST_DWithin3d($1, $2, $3)'
   LANGUAGE 'sql' IMMUTABLE
   COST 100;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/576#comment:4>
