[postgis-devel] [PostGIS] #576: 3d distance functions
PostGIS trac at osgeo.org
Thu Aug 26 22:54:29 PDT 2010
 Reporter:  nicklas      |       Owner:  nicklas
     Type:  enhancement  |      Status:  assigned
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by robe):
 Getting back to Mark's point about naming -- I think the way you have the
 functions named is fine for now as it follows convention.  Though I hate
 the current convention.  I would just like ST_length, ST_Area, ST_DWithin
 (and upcoming ST_Intersects), to not have 3D  and just use the highest
 dimension of input geometries.
 If its necessary to manage a dimension measurement lower than the
 dimension of the geometry, then we can pass in an optional dimension
 argument. I just like using the same code for both my 2D and 3 D work, and
 having to replace with 3D is just annoying and confusing because when I
 want a length/DWithin and I'm dealing with 3D I want a 3D length/distance.
 David Bitner -- you work with 3D probably more than the rest of us.
 What's your opinion on naming?
 Nicklas -- sorry for this long drawn out diatribe. Can you add in an
 ST_Intersects(I guess3D for now) and just have it piggy back on your
 ST_DWithin3D
Ticket URL: <http://trac.osgeo.org/postgis/ticket/576#comment:7>
