[postgis-devel] ST_Equals, immutable strict
Nicklas Avén nicklas.aven at jordogskog.no
Tue Aug 31 06:20:57 PDT 2010
2010-08-31 strk wrote:
On Tue, Aug 31, 2010 at 12:30:39PM +0200, Nicklas Avén wrote:
>> Hallo ST_Equals is marked as "immutable strict", other functions like ST_Intersects, ST_Within and so on is only marked "immutable" I guess that is why I have problems getting the index used for ST_Equals. Is there a reason for immutable strict on st_equals or is it a mistake? It is the same in trunk and 1.5.1 /Nicklas
>STRICT means that if any argument is NULL, then the result
>should also be NULL. Most likely ST_Intersects, ST_Within
>and others should be marked as strict too.
>--strk;
> Ok, but that seems to stop the index from working in st_equals. If I remove strict the index works as expected, but with strict it doesn't use the index. /Nicklas
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100831/6dfb3da1/attachment.html>
