[postgis-devel] Test: tin_tgeom throws segmentation fault
Olivier Courtin olivier.courtin at oslandia.com
Tue Aug 31 12:16:24 PDT 2010
On Aug 31, 2010, at 6:35 PM, Mateusz Loskot wrote:
Hi Mateusz,
> FYI, building PostGIS from the trunk r5875 under Linux 64-bit
> using GCC 4.4.3:
Ok many thanks for the report,
It should be fixed as r5878
Olivier
