[postgis-devel] [PostGIS] #670: ST_SharedPaths
PostGIS trac at osgeo.org
Fri Dec 3 01:04:21 PST 2010
 Reporter:  strk     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 Kind of crazy, I created a table with the result of the subquery, getting
 2 records with g1/g2 and could reproduce the crash using ST_SharedPaths
 against g1,g2 of first record.
 Those geometries I've put in the regression test and can't reproduce the
 issue.
 I wonder if it's a corruption somewhere else.
 Look at this:
 strk=# select st_sharedpaths(g1::text::geometry,g2::text::geometry) from
 bug670 where id = 1;
 ERROR:  GEOSIntersection: IllegalArgumentException: Geometry is not lineal
 strk=# select st_sharedpaths(g1,g2) from bug670 where id = 1;
 server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 The connection to the server was lost. Attempting reset: Failed.
 Note that ::text givesn HEXEWKT, so there should be nothing lost.
 I suspect there's some corruption in internal structures _before_
 SharedPaths is invoked.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/670#comment:5>
