[postgis-devel] [PostGIS] #670: ST_SharedPaths
PostGIS trac at osgeo.org
Fri Dec 3 14:12:46 PST 2010
  Reporter:  strk     |       Owner:  strk
      Type:  defect   |      Status:  reopened
  Priority:  high     |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment(by robe):
 I think so.  Unless Paul's shp2pgsql changes are impacting my build in a
 negative way thought he dll says it gets built and I did delete my whole
 folder and redownloaded.
 I'll try on another machine later.  If it isn't rebuilding for some
 reason, that could explain the ST_Snap problem.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/670#comment:12>
