[postgis-devel] POINT EMPTY in WKB
Paragon Corporation lr at pcorp.us
Mon Dec 6 13:22:41 PST 2010
 Though they seem to maintain the input display regardless.
What I the difference between these two geometries?
  SELECT Geometry::STGeomFromText('MULTIPOINT(EMPTY)',0).STAsText();
Yields:  MULTIPOINT (EMPTY)
   SELECT Geometry::STGeomFromText('MULTIPOINT EMPTY',0).STAsText();
Yields: MULTIPOINT EMPTY
Do we make a distinction between those?
-----Original Message-----
Sent: Monday, December 06, 2010 4:09 PM
To: 'PostGIS Development Discussion'
Subject: RE: [postgis-devel] POINT EMPTY in WKB
On my SQL Server 2008 the below
 SELECT Geometry::STGeomFromText('POINT EMPTY',0).STAsText();
Yields:
POINT EMPTY
Though I don't have the SQL server 2011 installed so who knows what that
returns.  It sounds like in next release they've got a pretty beefed up
curved support.  Even geodetic curved support and got rid of their
hemisphere restriction.
And
  SELECT Geometry::STGeomFromText('POINT(EMPTY)',0).STAsText();
Throws an error
A .NET Framework error occurred during execution of user-defined routine or
aggregate "geometry":
System.FormatException: 24141: A number is expected at position 11 of the
input. The input has EMPTY.
   at Microsoft.SqlServer.Types.OpenGisWktReader.RecognizeDouble()
   at Microsoft.SqlServer.Types.OpenGisWktReader.ParsePointText(Boolean
parseParentheses)
   at Microsoft.SqlServer.Types.OpenGisWktReader.ParseTaggedText(OpenGisType
type)
   at Microsoft.SqlServer.Types.OpenGisWktReader.Read(OpenGisType type,
Int32 srid)
   at Microsoft.SqlServer.Types.SqlGeometry.GeometryFromText(OpenGisType
type, SqlChars text, Int32 srid) .
But I'm not running R2 version I don't think:
Microsoft SQL Server 2008 (RTM) - 10.0.1600.22 (X64)   Jul  9 2008 14:17:44
Copyright (c) 1988-2008 Microsoft Corporation  Standard Edition (64-bit) on
Windows NT 5.2 <X64> (Build 3790: Service Pack 2)
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Monday, December 06, 2010 4:00 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] POINT EMPTY in WKB
It's just POINT EMPTY. Everything else has a representation. In fact, I
think Mats checked for me and SQLServer uses the same semantic as I am for
empties in WKB, npoints=0 or ngeoms=0 or nrings=0 depending on the type
being represented.
And I think for POINT EMPTY they transform to GEOMETRYCOLLECTION EMPTY.
(which is what we do now, see
  SELECT AsText('POINT EMPTY'::geometry);
P.
On Mon, Dec 6, 2010 at 12:48 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> A final possibility would be to hack POINT EMPTY into WKB, as
>> something like POINT(nan nan nan) or POINT(inf inf inf) or POINT(-0
>> -0 -0). There would be a danger there in platforms that have
>> different interpretations of what nan, inf or -0 are in binary.
> I the only issue with POINT EMPTY or ..anyspecifictype EMPTY
> I'm a bit bothered about the dump issue you describe -- not being able
> to restore exactly what you thought you had.
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
