[postgis-devel] [PostGIS] #681: ST_AsGML crashes on POLYGON EMPTY
PostGIS trac at osgeo.org
Wed Dec 8 09:26:13 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Crash
 SELECT ST_AsGML(ST_GeomFromText('POLYGON EMPTY',4326)) As result
 -- though this works okay --
 {{{SELECT ST_AsGML(ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326)) As
 result;
 yields which is same answer as 1.5:
 <gml:MultiGeometry srsName="EPSG:4326"></gml:MultiGeometry>
 -- and this works okay --
 SELECT ST_AsGML(ST_GeomFromText('POINT EMPTY',4326)) As result;
 yields below which is not the same answer as 1.5, but I assume that is a
 planned change.
 <gml:MultiPoint srsName="EPSG:4326"></gml:MultiPoint>
Ticket URL: <http://trac.osgeo.org/postgis/ticket/681>
