[postgis-devel] [PostGIS] #686: Issues with TRIANGLE AND TIN EMPTY collections - hmm do they exist?
PostGIS trac at osgeo.org
Wed Dec 8 13:00:40 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 This may not be a bug, but I figured you may be getting bored :)
  does OGC have a concept of TIN, TRIANGLE,  empties?
 SELECT  ST_COLLECT(ST_GeomFromText('POLYGON
 EMPTY',4326),ST_GeomFromText('TRIANGLE EMPTY',4326)) ;
 gives error:
 ERROR:  getPoint_internal called outside of ptarray range (n=0,
 pa.npoints=0, pa.maxpoints=0)
 I'll check some others.
 Should this be legal? All TIN TRIANGLE Give invalid OGC WKT (too short)
 SELECT  ST_COLLECT(ST_GeomFromText('TIN EMPTY',4326),ST_GeomFromText('TIN
 EMPTY',4326)) ;
 SELECT  ST_GeomFromText('TIN EMPTY',4326) ;
 That yields a:
 OGC WKT (too short)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/686>
