[postgis-devel] [PostGIS] #703: measures test failure
PostGIS trac at osgeo.org
Mon Dec 13 03:02:00 PST 2010
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by mcayland):
 Nicklas,
 Could it be that you have a robustness issue in your distance algorithm? I
 remember experiencing similar problems when a fixing bugs in past, related
 to bad use of floating point arithmetic when the values are close to each
 other.
 Would you be able to step through this query on a 32-bit machine to find
 out how the error is being introduced?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/703#comment:4>
