[postgis-devel] [PostGIS] #31: Negative distance buffer
PostGIS trac at osgeo.org
Mon Dec 13 13:48:12 PST 2010
 Reporter:  joao...@…          |         Type:  defect
   Status:  new                |     Priority:  medium
Milestone:  PostGIS 1.4.3      |    Component:  postgis
  Version:  1.4.X              |   Resolution:  accepted
 Keywords:                     |
Changes (by pramsey):
  * status:  accepted => new
  * version:  => 1.4.X
  * milestone:  => PostGIS 1.4.3
Old description:
> I’ve detected a possible bug or at least a bizarre behavior when
> performing
> a buffer query with negative distances (e.g.: SELECT
> st_buffer(a.the_geom,
> -5.725)...). In some cases interior rings are not being used to perform
> the
> inner buffer generation (this is illustrated by the reddish features in
> the
> image attachment) although for most of the cases rings are correctly used
> (green features).
>  Tests using polygon/multipolygon themes revealed the same result. I've
> compared the areas of buffered and non-buffered polygons with very small
> distances, and in some cases the negative buffered area is bigger
> revealing
> the inclusion of the rings areas.
>  Performing an intersction positevely identifies the problematic
> polygons:
> SELECT  a.gid,
>         a.the_geom
> FROM    original a, negative_buffer b
> WHERE   st_intersects(a.the_geom, b.st_buffer) AND a.gid<>b.gid;
> Enviroment:
> -- WinXP SP2
> -- PostgreSQL 8.2.0.7
> -- PostGIS 1.3.3 (data imported under 1.3.2)
New description:
 performing
 a buffer query with negative distances (e.g.: SELECT st_buffer(a.the_geom,
 the
 the
 (green features).
 revealing
  Performing an intersction positevely identifies the problematic polygons:
 SELECT  a.gid,
         a.the_geom
 Enviroment:
 -- WinXP SP2
Comment:
 Filed in GEOS at http://trac.osgeo.org/geos/ticket/194
Ticket URL: <http://trac.osgeo.org/postgis/ticket/31#comment:9>
