[postgis-devel] [PostGIS] #547: ST_contains memory problem when used between polygon and mixed geometry
PostGIS trac at osgeo.org
Mon Dec 13 21:40:07 PST 2010
 Reporter:  twain               |       Owner:  pramsey
     Type:  defect              |      Status:  new
 Priority:  high                |   Milestone:  PostGIS 1.5.3
Component:  postgis             |     Version:  1.5.X
 Keywords:  ST_contains memory  |
Comment(by pramsey):
 If you're still there I'd be interested if the attached patch resolves the
 problem.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/547#comment:2>
