[postgis-devel] [PostGIS] #709: cunit tests fail cu_tester crashes on out_kml_test_precision KML test
PostGIS trac at osgeo.org
Tue Dec 14 23:08:38 PST 2010
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 With latest trunk my cunit is okay and the above example works, however
 you seem to have screwed up the POLYGON EMPTY case.  I'll add that to the
 reopened GML ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/709#comment:2>
