[postgis-devel] loader/cunit
strk strk at keybit.net
Thu Dec 16 06:36:36 PST 2010
On Thu, Dec 16, 2010 at 11:33:21AM +0000, Mark Cave-Ayland wrote:
> strk wrote:
> >Going on with my SUBDIR-based makefiles I stubled upon
> >loader/cunit dir (running 'make check' under loader).
> >W/out my change, those unit test don't run at all, is
> >that expected ? Running the tests give lots of failures.
> >So, are those tests meant to be run and should thus be fixed ?
> >Or should they be just NOT run (and thus probably dropped) ?
> Hmmm it looks like it was something Mark (Leslie) was working on, though
> I get GTK reference errors so they would have absolutely no chance of
> running unless ./configure was run with --with-gui.
Alright then, as of r6414 'make check' under loader/  only runs the test
when --with-gui was passed.
When I'm finished with the top-level-dir pass this will be true also
from the top-level dir...
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
