[postgis-devel] [PostGIS] #718: Catch dimensionally mixed WKB collections
PostGIS trac at osgeo.org
Fri Dec 17 16:21:12 PST 2010
 Reporter:  pramsey      |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
 If someone submits dimensionally mixed WKB collections, it will be read
 into LWGEOM objects and then the dimensionality bits may be set from above
 into the wrong values. This could result in a 2d subobject being read as
 3d, with a nasty result. The WKB reader needs to die if handed
 dimensionally mixed WKB collections.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/718>
