[postgis-devel] PostGIS Raster
cesius emilio.detorres at fueca.es
Tue Dec 21 04:31:05 PST 2010
Thank you so much for your detailed help, I'll try it.
Regards.
Jorge Arévalo-2 wrote:
> On Tue, Dec 21, 2010 at 10:10 AM, cesius <emilio.detorres at fueca.es> wrote:
>> Hello,
>> I have to develop an application where it's necessary to find the
>> satellite
>> image (GeoTIFF) which a point, given its lat-long, belongs to.
>> Can PostGIS Raster do a query of this kind? How coul I do it? I have find
>> the ST_Envelope function but it returns the four corners of a rectangle
>> and
>> my images are no regular polygons.
>> Thank you very much.
>> View this message in context:
>> http://old.nabble.com/PostGIS-Raster-tp30471969p30471969.html
>> Sent from the PostGIS - Dev mailing list archive at Nabble.com.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> Hello,
> You can try this:
> 0.- Create a PostGIS Raster-enabled database. Check this:
> http://postgis.refractions.net/documentation/manual-svn/RT_FAQ.html#id3022293
> 1.- Load each GeoTiff file in a different table (assuming you want to
> identify the concrete GeoTiff file each point belongs to)
> raster2pgsql -r /path/to/raster/file.tif -t table1 -s <file_srid> -l 1
> -M -I -o file1.sql [-k widthxheight]
> psql -U your_user -W -d your_database -f file1.sql
> The "-k" option is useful if your GeoTiff files are big. In that case,
> the GeoTiff file will be tiled and each tile will be stored in a
> table's row. If you don't specify it, the whole raster file will be
> loaded in only one table's row.
> Repit this step with each GeoTiff file, changing the name of the
> table. You can store all the GeoTiff files in one table, but in that
> case, you wouldn't know what was the original GeoTiff file each point
> belongs to (not in an easy way, at least)
> 2.- Use ST_World2RasterCoordX, ST_World2RasterCoordY functions
> (http://postgis.refractions.net/documentation/manual-svn/RT_ST_World2RasterCoordX.html,
> http://postgis.refractions.net/documentation/manual-svn/RT_ST_World2RasterCoordY).html
> with each point and each table. A PL/pgSQL script may help you to
> automate this process.
> Hope it works...
> Best regards,
> Jorge Arévalo
> Internet & Mobilty Division, DEIMOS
> jorge.arevalo at deimos-space.com
> http://mobility.grupodeimos.com/
> http://gis4free.wordpress.com
> http://geohash.org/ezjqgrgzz0g
View this message in context: http://old.nabble.com/PostGIS-Raster-tp30471969p30505761.html
