[postgis-devel] [PostGIS] #730: Raster is broken -- no casts
PostGIS trac at osgeo.org
Thu Dec 23 20:21:11 PST 2010
 Reporter:  robe            |       Owner:  pramsey
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 Mat,
 fine with me.  You know what to take care of?  I think st_box2d Paul
 removed leaving box2d.  The other operators we are removing entirely so I
 think those that are failing can just be deleted unless you see a need for
 them in which case you should raise it on devel newsgroup.
 I'm going to have to revise the docs to remove all these operators for
 both PostGIS and raster (since a lot of my PostGIS operator tests
 generated from the docs are failing too).
 I'm waiting for final consensus on what we keep and let go before I do
 that.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/730#comment:6>
