[postgis-devel] [PostGIS] #735: regress failed
PostGIS trac at osgeo.org
Tue Dec 28 07:40:32 PST 2010
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by robe):
 Actually I get a lot of errors too running 9.0.0 windows (mingw 32-bit)
 with gserialized on. Don't recall getting this many before (aside from the
 one's Paul said would fail)
  PostgreSQL 9.0.0, compiled by Visual C++ build 1500, 32-bit
  Postgis 2.0.0SVN - 2010-12-28 11:45:17
    GEOS: 3.3.0-CAPI-1.7.0
    PROJ: Rel. 4.6.1, 21 August 2008
 Running tests
  loader/Point.............. ok
  loader/PointM.............. ok
  loader/PointZ.............. ok
  loader/MultiPoint.............. ok
  loader/MultiPointM.............. ok
  loader/MultiPointZ.............. ok
  loader/Arc.............. ok
  loader/ArcM.............. ok
  loader/ArcZ.......... ok
  loader/Polygon.............. ok
  loader/PolygonM.............. ok
  loader/PolygonZ.............. ok
  regress. failed (diff expected obtained: /tmp/pgis_reg_5480/test_13_diff)
  regress_index. ok
  regress_index_nulls. ok
  lwgeom_regress. failed (diff expected obtained:
 /tmp/pgis_reg_5480/test_16_diff)
  regress_lrs. ok
  removepoint. ok
  setpoint. ok
  simplify. ok
  snaptogrid. ok
  affine. ok
  measures. ok
  long_xact. ok
  ctors. ok
  sql-mm-serialize. ok
  sql-mm-circularstring. failed (diff expected obtained:
 /tmp/pgis_reg_5480/test_27_diff)
  sql-mm-compoundcurve. ok
  sql-mm-curvepoly. ok
  sql-mm-general. ok
  sql-mm-multicurve. ok
  sql-mm-multisurface. ok
  polyhedralsurface. ok
  out_geometry. ok
  out_geography. ok
  in_gml. ok
  in_kml. ok
  iscollection. ok
  regress_ogc. ok
  regress_ogc_cover. ok
  regress_ogc_prep. ok
  regress_bdpoly. ok
  regress_proj. ok
  dump. failed (diff expected obtained: /tmp/pgis_reg_5480/test_44_diff)
  dumppoints. ok
  wmsservers. ok
  tickets. failed (diff expected obtained: /tmp/pgis_reg_5480/test_47_diff)
  remove_repeated_points. ok
  split. ok
  relatematch. ok
  regress_buffer_params. ok
  hausdorff. ok
  clean. ok
  sharedpaths. ok
  snap. ok
 Run tests: 55
 Failed: 5
Ticket URL: <http://trac.osgeo.org/postgis/ticket/735#comment:1>
