[postgis-devel] [PostGIS] #703: measures test failure
PostGIS trac at osgeo.org
Tue Dec 28 23:13:33 PST 2010
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by nicklas):
 Hmm, I jst read some more from #503 and saw that you, Mark, mentioned that
 we actually compile with -ffloat-store flag.
 Mark, why did you then ask me to try with that flag?
 I ask because in my example above when I ran the problem part of the code
 outside postgis and postgresql, the -ffloat-store flag solved the problem.
 But why doesn't it solve the problem inside postgis?
 Do we, or do we not use -ffloat-store flag? I see it gets there correctly
 (as I understand it) in the makefile when I run ./configure, but it
 doesn't solve the problem.
 And again, if we already use it, why did you want me to test it again,
 Mark. It is something here I don't understand.
 /Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/703#comment:16>
