[postgis-devel] [PostGIS] #740: Something is really messed up with the gserialized or my install of it
PostGIS trac at osgeo.org
Thu Dec 30 08:35:01 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Paul,
 Can you look at these and confirm you have the same issues.  I'm not sure
 if I somehow mixed up my installs or these are true issues.
 I did these tests before moving forward with the speed compares you
 discussed.  I then stopped when I started seeing these bizarre differences
 between the 2.
 To compile -- I first enabled gserialized in gserialize.h then did my
 usual install on a parallel postgresql 9.0 windows 32 bit.
 Then I repeated the same exercise with default gserialized disabled.
 1) Looks like we are missing all those over left, over right operators
 Mark whined about.  Is that intentional (since my raster install complains
 when installing it from the gserialized batch of scripts (postgis.sql,
 rtpostgis.sql)).
 2) ST_IsClosed crashes with LINE Empty (again works or at least doesn't
 crash with gserialized disabled.
 --- gserialized ST_IsClosed --
 SELECT ST_IsClosed(ST_GeomFromText('LINESTRING EMPTY',4326));
 --server crashes--
 3) This one I wanted to simplify to make it easier to inspect. I can't
 figoure what is wrong with this.  I tried to dissect it, but I can't
 rebuild the geometry from the ST_AsEWKT of the
 outputs -- complains about polygons not well formed (the error you get
 when you have non-closed polygons) or something
 -- create table
 SELECT ST_Collect(geom) As geom
 INTO test_collgeomm
 FROM
 (VALUES ( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGONM(((-71.0821 42.3036
 2,-71.0822 42.3036 3,-71.082 42.3038 2,-71.0819 42.3037 2,-71.0821 42.3036
 2)))') ),
         ( ST_GeomFromEWKT('SRID=4326;POLYGONM((-71.1261 42.2703 1,-71.1257
 42.2703 1,-71.1257 42.2701 2,-71.126 42.2701 1,-71.1261 42.2702 1,-71.1261
 42.2703 1))') )
                 )       As g(geom) CROSS JOIN generate_series(1,3) As i
                 GROUP BY i;
                 -- run query
 SELECT ST_DFullyWithin(f1.geom, f2.geom,100)
 FROM test_collgeomm As f1 CROSS JOIN test_collgeomm As f2;
 -- get error --
 ERROR:  Return size (160) not equal to expected size (152)!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/740>
