[postgis-devel] Gserialized Enabled vs Disabled
Paragon Corporation lr at pcorp.us
Thu Dec 30 23:00:53 PST 2010
Yap this returns true on both:
SELECT ST_Disjoint(ST_GeomFromEWKT('SRID=4326;LINESTRING(-11.1111111 40,
-11.111111 40.2)'),ST_GeomFromEWKT('SRID=4326;TRIANGLE((-71.0821
42.3036,-71.0821 42.3936,-71.0901 42.3036,-71.0821 42.3036))'))
So I guess that solves that little mystery.  Which to me would seem to cause
needless churning for gserialized when dealing with points no?
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Friday, December 31, 2010 1:44 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Gserialized Enabled vs Disabled
(And you can prove this is so by replacing your POINT in the example with a
short LINESTRING.)
On Thu, Dec 30, 2010 at 10:43 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> There's a difference in behavior in the box retrieval functions. The
> old ones would first try and pull the box off the geometry
> serialization, and if that fails, compute one. The new one just tries
> to pull one off the serialization, and if it fails, returns failure.
> So the code in the second one skips the box test. As it stands now,
> the only kind of object that doesn't have a serialized box is a point,
> so this could probably be worked around.
> P.
> On Thu, Dec 30, 2010 at 10:06 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> I'm seeing a bunch of differences when doing a regress compare
>> between these two
>> Mostly with the way they handle empty geometries and the newer types
>> like TIN.
>> It's almost as if the serialized is not doing any short-circuiting
>> and the non-serialized is.
>> For example:
>> 1)  SELECT ST_Disjoint(ST_GeomFromEWKT('SRID=4326;POINT(-11.1111111
>> 40)'),
>> ST_GeomFromEWKT('SRID=4326;TRIANGLE((-71.0821 42.3036,-71.0821
>> In the regular case - non-gserialized:
>> This returns: t
>> In the gserialized -- this returns
>> Unknown geometry type: 14 - Triangle
>> So it's like the non-gserialized is smart enough to realize that if
>> the bounding box does not intersect there is no need to jump into
>> geos or do anything further analysis - it knows they are disjoint.
>> I'm seeing a lot of these silly failures.  Which are perhaps by design.
>> Thanks,
>> Regina
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
