[postgis-devel] [PostGIS] #746: ST_Dump with GSerialized POINT EMPTY and EWKT/AsText mismatch? (was: ST_Dump with GSerialized POINT EMPTY does not match expected size)
PostGIS trac at osgeo.org
Fri Dec 31 10:58:42 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Okay I stand corrected.  Evidentally you can get back a POINT EMPTY in
 gserialized if you use ST_AsText, but not if you use ST_AsEWKT.  There is
 a big disconnect there.
 Example:
 SELECT ST_AsText(ST_GeomFromText('POINT EMPTY'));
 -- gserialized
 POINT EMPTY
 -- out current install (not gserialized)
 MULTIPOINT EMPTY
 If you use ST_AsEWKT in both cases its
 MULTIPOINT EMPTY
 This AsEWKT/AsText mismatch in GSerialized may explain the large number of
 discrepancies I'm seeing between the two during my regress checks.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/746#comment:1>
