[postgis-devel] 1.5.0rc2 - FAST TURNAROUND
Kevin Neufeld
kneufeld at refractions.net
Mon Feb 1 12:24:13 PST 2010
Regression tests pass for me as well on centos 5.2, geos 3.2.0, proj 4.6.1, psql 8.3 and 8.4.2.
However, when I try to create a new database myself, I get a whole lot of DROP FUNCTION NOTICES after the final COMMIT
in postgis.sql
It's like an upgrade script was accidently appended to the usual postgis function install. This is going to cause a lot
of confusion.
CREATE FUNCTION
CREATE FUNCTION
COMMIT
psql:/var/home/buildbot/opt/pgsql/8.4/share/contrib/postgis-1.5/postgis.sql:7744: NOTICE: aggregate geomunion(geometry)
does not exist, skipping
DROP AGGREGATE
psql:/var/home/buildbot/opt/pgsql/8.4/share/contrib/postgis-1.5/postgis.sql:7745: NOTICE: aggregate
st_geomunion(geometry) does not exist, skipping
DROP AGGREGATE
psql:/var/home/buildbot/opt/pgsql/8.4/share/contrib/postgis-1.5/postgis.sql:7746: NOTICE: aggregate accum_old(geometry)
DROP AGGREGATE
psql:/var/home/buildbot/opt/pgsql/8.4/share/contrib/postgis-1.5/postgis.sql:7747: NOTICE: aggregate
st_accum_old(geometry) does not exist, skipping
DROP AGGREGATE
psql:/var/home/buildbot/opt/pgsql/8.4/share/contrib/postgis-1.5/postgis.sql:7750: NOTICE: function
box2d_overleft(box2d,box2d) does not exist, skipping
-- Kevin
On 2/1/2010 11:31 AM, Paul Ramsey wrote:
> Regression on OpenSolaris passes.
> On Mon, Feb 1, 2010 at 10:27 AM, Paul Ramsey<pramsey at opengeo.org> wrote:
>> Regression test on OS/X 10.6.2 passes.
>>> Regression test on Centos 5.4 passes.
>>> On Mon, Feb 1, 2010 at 9:48 AM, Paul Ramsey<pramsey at opengeo.org> wrote:
>>>> OK, I have run astyle and placed the current tarball at
>>>> http://postgis.refractions.net/download/postgis-1.5.0rc2.tar.gz
>>>> Please download and run make check on this source ASAP on your
>>>> systems. If there have been no critical bug reports by Wednesday
>>>> morning my time, I am going to drop 1.5.0.
>>>> Go go go go go!
>>>> Paul
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
