[postgis-devel] Feb. Code Sprint and WKTRaster?
Mateusz Loskot
Mateusz.Loskot at cadcorp.com
Tue Feb 2 02:35:54 PST 2010
Pierre Racine wrote:
> Be careful of not confusing georeference and coordinate system.
Yes, I apparently confused both while thinking
about the ST_SetGeoReference function.
> The georeference is given by 6 float numbers and is only te location of the
> raster in space. WKT/PROJ.4 definitions refer to coordinate systems
> which are provided to WKT Raster through the ST_SetSRID function. Both
> function should be straighforward to implement. There should also be a
> ST_SetGeoReference(raster, float, float, float, float, float, float)
> variant.
Right and good point about the variant.
Best regards,
Mateusz Loskot
Senior Programmer, Cadcorp
http://www.cadcorp.com
This email is confidential and may be privileged and should not be used, read
or copied by anyone who is not the original intended recipient. If you have
received this email in error please inform the sender and delete it from
your mailbox or any other storage mechanism. Unless specifically stated,
nothing in this email constitutes an offer by Cadcorp and Cadcorp does not
warrant that any information contained in this email is accurate.
Cadcorp cannot accept liability for any statements made which are clearly the
sender's own and not expressly made on behalf of Cadcorp or one of its agents.
Please rely on your own virus check. No responsibility is taken by Cadcorp
for any damage arising out of any bug or virus infection.
