[postgis-devel] [PostGIS] #403: pgsql2shp gives deceptive message about not having PostGIS installed
PostGIS trac at osgeo.org
Tue Feb 2 06:16:30 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS Future
Component:  postgis  |     Version:  trunk
 Keywords:           |
 If I use pgsql2shp on a database that doesn't have geography data type,
 you get this message
 Geometry type unknown (have you enabled postgis?)
 And then the system happily outputs the data.
 Seems to be the getGeographyOID at fault.  At the very least we should
 change the message to
 Geography type unknown
 Unless of course we don't allow people to output their older dbs with
 newer versions of the dumper.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/403>
