[postgis-devel] [PostGIS] #408: Catch "Exception in LWGEOM2GEOS" in ST_IsValid
Martin Davis mbdavis at refractions.net
Thu Feb 4 13:35:20 PST 2010
Yeah, but isn't it a pain to trap exceptions inside an SQL statement?
And slow to try and do it using a plpqsl function?
strk wrote:
> I might be missing something, but wouldn't an exception
> from LWGEOM2GEOS mean unambiguosly that the geometry
> is invalid ?
> ... thinkin loud ... could also be an OOM actually ...
> --strk;
> On Thu, Feb 04, 2010 at 01:26:38PM -0800, Martin Davis wrote:
>> Right, this has just been explained to me by our resident PostGIS expert
>> Kevin.  To repeat his explanation, the PostgreSQL language engine is
>> auto-converting the string to a Geometry type, since that's what
>> st_isvalid accepts.  This is where the exception is happening - which
>> means that it can't be caught inside st_isvalid.
>> I would humbly suggest that it would be nice to be able to prevent C
>> exceptions leaking out into the SQL world where possible. Perhaps a
>> st_isvalid_safe(String geomWKT)
>> could be provided to allow users to avoid this.  (And since Kevin also
>> pointed out that this doesn't allow distinguishing between Geometry and
>> the new Geography type, a
>> st_isvalid_geog_safe(String geogWKT)
>> might be needed as well.
>> Code it up and let the users vote with their keyboards!
>>>  Reporter:  ddegasperi   |       Owner:  pramsey
>>>      Type:  enhancement  |      Status:  new
>>>  Priority:  medium       |   Milestone:
>>> Component:  postgis      |     Version:  1.4.X
>>> Resolution:               |    Keywords:
>>> Comment (by pramsey):
>>> Non possible.
>>> The '':text entry first gets passed into the text parsing routines which
>>> is where the failure actually occurs, not in st_isvalid. We have had
>>> internal arguments many times about where validity checking should occur,
>>> and the current situation is that trivially invalid geometries (1-point
>>> lines, unclosed polygons) are failed during parsing.
>>> IMO, they shouldn't fail, but that's a personal opinion, not a consensus
>>> one.
>> Martin Davis
>> Senior Technical Architect
>> Refractions Research, Inc.
>> (250) 383-3022
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Martin Davis
(250) 383-3022
