[postgis-devel] Has anyone seen this before?
Paragon Corporation lr at pcorp.us
Fri Feb 5 14:45:59 PST 2010
I'll try to do that on a local pc since this one they use as a workhorse for
processing, so can't mess with it too much.
I'm pulling the good table down and see if I can replicate the bad behavior
on my local machine.
thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Friday, February 05, 2010 5:38 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Has anyone seen this before?
Compile your pgsql with --enable-cassert and run your selection of commands
again. Hopefully you'll get a big bad error at some point as a memory
operation wanders off the reservation.
P
On Fri, Feb 5, 2010 at 1:55 PM, Paragon Corporation <lr at pcorp.us> wrote:
> What would result in an UNKNOWN geometry type.  One of our clients is
> getting this error when they try to vacuum analyze their table.
>> NOTICE:  compute_serialized_box3d called on unknown type 0NOTICE:
>> compute_serialized_box3d called on unknown type 0 ...
> On closer inspection -- I see that there are UNKNOWNs and those
> UNKNOWNS are not NULL but the ST_AsText looks blank viewed via psql
> select count(*),  GeometryType(the_geom) from badtable group by
> GeometryType(the_geom);
>  count | geometrytype
>  98483 | MULTIPOLYGON
>  1517 | UNKNOWN
> This is running on
>  POSTGIS="1.3.6" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.6.0, 21 Dec 2007"
> USE_STATS
> PostgreSQL 8.4.1 on x86_64-redhat-linux-gnu, compiled by GCC gcc (GCC)
> 4.1.2 20
> 071124 (Red Hat 4.1.2-42), 64-bit
> They say the table was created by doing a
> create table badtable as select * from goodtable order by
> addr_num_tlid limit 100000;
> the goodtable doesn't exhibit this bizarre behavior.  Not sure if this
> is a PostgreSQL bug or PostGIS bug.
> Any thoughts?
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
