[postgis-devel] [PostGIS] #410: ST_SetPoint and bounding box
PostGIS trac at osgeo.org
Sat Feb 6 19:09:16 PST 2010
  Reporter:  sdikiy    |       Owner:  pramsey
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:
 Component:  postgis   |     Version:  1.4.X
Resolution:  invalid   |    Keywords:  ST_SetPoint
Changes (by robe):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 sdikiy,
 Which version of PostgreSQL are you running?
 Do a
 SELECT version();
 I believe the error you are experiencing is not a PostGIS bug, but a
 PostgreSQL bug that was fixed in later versions of PostgreSQL.
 If you are running PostgreSQL 8.3, make sure you are running 8.3.7 or
 above.  You should preferably be running the latest version 8.3.9.  For
 PostgreSQL 8.4, you should be running 8.4.1 or 8.4.2.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/410#comment:2>
