[postgis-devel] [PostGIS] #411: Invalid geometries are accepted in DB but no way to take them out
PostGIS trac at osgeo.org
Mon Feb 8 12:17:47 PST 2010
  Reporter:  strk      |       Owner:  strk
      Type:  defect    |      Status:  reopened
  Priority:  critical  |   Milestone:  PostGIS 1.4.2
 Component:  postgis   |     Version:  1.4.X
Resolution:            |    Keywords:
Changes (by mcayland):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 While this allows you to unparse invalid geometries, it is not a fix
 because you haven't stopped the invalid geometries getting into the
 database in the first place. Can you take a look at which validity check
 is failing before closing? Unfortunately the shapefile itself doesn't
 appear to be attached to the ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/411#comment:8>
