[postgis-devel] [PostGIS] #399: ST_CleanGeometry
PostGIS trac at osgeo.org
Wed Feb 10 13:28:28 PST 2010
  Reporter:  strk     |       Owner:  strk
      Type:  task     |      Status:  assigned
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:
Resolution:           |    Keywords:
Changes (by strk):
  * status:  new => assigned
Comment:
 Here's an interesting case for you guys to play with:
  POLYGON((10 10,10 20,30 20,30 10,20 10,20 30,30 30,30 20,5 20,5 25,10 25,
 10 10))
 If the goal of a ST_CleanGeometry is to maintain as much information from
 the input
 but make it into a valid shape, the above would sound to me as becoming a
 mix
 of two polygons and two lines.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/399#comment:11>
