[postgis-devel] [PostGIS] #399: ST_CleanGeometry
PostGIS trac at osgeo.org
Fri Feb 12 11:50:14 PST 2010
  Reporter:  strk     |       Owner:  strk
      Type:  task     |      Status:  assigned
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:
Resolution:           |    Keywords:
Comment (by strk):
 Alright, here is my client suggestion for the ST_GeometryClean contract:
  - Returned geometry will have same dimensionality of input
  - No vertices from original geometry will be discarded
  - The returned geometry will be valid
  Failing any of the above should throw an exception.
  Adding vertices is fine.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/399#comment:15>
