[postgis-devel] [PostGIS] #417: crash in parser
PostGIS trac at osgeo.org
Mon Feb 15 14:36:13 PST 2010
  Reporter:  strk     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  blocker  |   Milestone:
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by kneufeld):
 I don't have this problem using PostGIS 1.5.0.
 Instead, I get:
 postgis=# select '0102000000010000000000000000'::geometry;
 ERROR:  parse error - invalid geometry
 LINE 1: select '0102000000010000000000000000'::geometry;
 HINT:  You must specify a valid OGC WKT geometry type such as POINT,
 LINESTRING or POLYGON
Ticket URL: <http://trac.osgeo.org/postgis/ticket/417#comment:1>
