[postgis-devel] [PostGIS] #417: crash in parser
trac at osgeo.org
Mon Feb 15 15:13:03 PST 2010
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone:
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
On my 1.4.1 windows stack builder install, I get the same thing as Kevin.
ERROR: parse error - invalid geometry
LINE 1: select '0102000000010000000000000000'::geometry;
HINT: You must specify a valid OGC WKT geometry type such as POINT,
LINESTRING or POLYGON.
Sandro what OS are you running on? Wonder if its a 64-bit issue. I can
try on my 64-bit Linux dev box later.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/417#comment:2>
