[postgis-devel] [PostGIS] #418: ST_Transform() doc inaccurately claims SF1.1
PostGIS trac at osgeo.org
Tue Feb 16 15:40:43 PST 2010
  Reporter:  warmerdam  |       Owner:  pramsey
      Type:  defect     |      Status:  new
  Priority:  low        |   Milestone:
 Component:  postgis    |     Version:  1.5.X
Resolution:             |    Keywords:
Comment (by pramsey):
 It can be found instead in section 5.1.6 of SQL/MM Part 3. I wonder if I
 should go through and put in the SQL/MM references everywhere. Phew..
Ticket URL: <http://trac.osgeo.org/postgis/ticket/418#comment:1>
