[postgis-devel] Please 'make style' before committing
strk strk at keybit.net
Sun Feb 21 04:57:06 PST 2010
For the record, I'm using
Artistic Style Version 1.22
--strk;
On Sun, Feb 21, 2010 at 01:55:13PM +0100, strk wrote:
> On Sun, Feb 21, 2010 at 07:41:39AM -0500, Olivier Courtin wrote:
> > Just launched a make astyle on trunk root and commited
> > as r5274.
> Alright, we have a problem here.
> I did run make astyle before you, but I do see that your run
> further modifies the input. I then checked out your version
> again and run 'make astyle' on it. Here are the changed files:
> M      liblwgeom/lwsegmentize.c
> M      liblwgeom/lwspheroid.c
> M      postgis/geography_inout.c
> M      postgis/lwgeom_gist.c
> M      postgis/lwgeom_inout.c
> M      postgis/lwgeom_in_gml.c
> M      postgis/lwgeom_in_kml.c
> M      extras/wkb_reader/readwkb.c
> Example changes (lwsegmentize.c):
> Index: liblwgeom/lwsegmentize.c
> --- liblwgeom/lwsegmentize.c    (revision 5274)
> +++ liblwgeom/lwsegmentize.c    (working copy)
> @@ -157,9 +157,9 @@
>         POINT4D *center;
>         double radius = 0.0,
> -              sweep = 0.0,
> -              angle = 0.0,
> -              increment = 0.0;
> +                       sweep = 0.0,
> +                               angle = 0.0,
> +                                       increment = 0.0;
>         double a1, a2, a3, i;
>         LWDEBUG(2, "lwcircle_segmentize called. ");
> So, anyone sees a chance to be more explicit on astyle configuration
> for how to deal with that ?
