[postgis-devel] Please 'make style' before committing
Mateusz Loskot mateusz at loskot.net
Mon Feb 22 10:36:50 PST 2010
Chris Hodgson wrote:
> Guys, I already looked into this, you can't (well, at least shouldn't)
> do it in a pre-commit hook because it confuses your svn client. It
> doesn't expect files to get modified during the commit process (other
> than by specific built-in handlers for eol and variable expansion) and
> so when they are, later update checks are confused by files which are
> the same revision, but are cleaned-up by astyle in the repo and not in
> your local checkout - you end up with a borked sandbox and have to do a
> fresh checkout. Best you can do is run it in "check" mode and not allow
> commits with bad style. Which might be nice, but I don't think you'd
> want to do it until everyone was on board and the kinks are worked out.
> At which point it probably wouldn't be necessary.
Chris,
This is a very good point and a good point against my idea.
I've missed that I admit.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
