[postgis-devel] [PostGIS] #440: [wktraster] Consolidate st_gdalgeotransform and st_esriworldfile into st_georeference
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Mon Feb 22 12:49:56 PST 2010
Once you have the plPgSQL version, could you compare the speed of the C and the plPgSQL ones on a table containing, let say thousands tiles. This way we can validate that plPgSQL is not MUCH slower than C for simple functions like this. That would be great!
Pierre
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of David Zwarg
>Sent: 22 février 2010 15:45
>To: PostGIS Development Discussion
>Subject: Re: [postgis-devel] [PostGIS] #440: [wktraster] Consolidate st_gdalgeotransform and
>Ok, sorry to pollute trac.
>I was going to implement this common method in plPgSQL, since there
>isn't a compelling reason to do it in C -- there's nothing special
>happening in the GDAL C method.  I can set it up so that it defaults
>to GDAL.
>Thanks,
>Zwarg
>On Mon, Feb 22, 2010 at 3:32 PM, Pierre Racine
><Pierre.Racine at sbf.ulaval.ca> wrote:
>> Maybe we should agree on changes in the specs in the forum before polluting Trac too much.
>> Otherwise I agree with this change. The default should be 'GDAL' if no second parameter is passed.
>> Is it really faster to implement such a function in C instead of plPgSQL? I know one is implemented
>in C and the other one in plPgSQL.
>> Pierre
>>>bounces at postgis.refractions.net] On Behalf Of PostGIS
>>>Sent: 22 février 2010 15:16
>>>Cc: postgis-devel at postgis.refractions.net
>>>Subject: [postgis-devel] [PostGIS] #440: [wktraster] Consolidate st_gdalgeotransform and
>>>st_georeference
>>> Reporter:  dzwarg     |       Owner:  dzwarg
>>>     Type:  task       |      Status:  new
>>> Priority:  medium     |   Milestone:  WKTRaster 0.1.6
>>>Component:  wktraster  |     Version:  trunk
>>> Keywords:             |
>>> Consolidate the georeference get methods into a single get method, with 1
>>> parameter that switches between GDAL and ESRI output.
>>>  * ST_GeoReference(raster, 'ESRI'|'GDAL') -> string
>>> See [wiki:WKTRaster/SpecificationWorking01#Objective0.1.6d-
>>> BeingabletogetallthepropertiesofarasteralltheGetfunctions
>>> SpecificationWorking01]
>>>Ticket URL: <http://trac.osgeo.org/postgis/ticket/440>
>>>PostGIS <http://trac.osgeo.org/postgis/>
>>>The PostGIS Trac is used for bug, enhancement & task tracking, a user and developer wiki, and a
>>>view into the subversion code repository of PostGIS project.
>>>_______________________________________________
>>>postgis-devel mailing list
>>>http://postgis.refractions.net/mailman/listinfo/postgis-devel
