[postgis-devel] [PostGIS] #368: Geography showing cryptic type
PostGIS trac at osgeo.org
Sun Jan 3 10:12:00 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 I hope this has been fixed since.  I just got around to stress testing the
 12/30 build I did and when I create a geography table and look at the
 CREATE TABLE in pgadmin it looks like
 So for example if I created a table as
 CREATE TABLE pgis_geoggarden(gid serial NOT NULL, the_geog
 geography(POINT));
 When I relook at it, it looks like this:
   the_geog geography(1107456)
 Can you check and see if it shows similar anomaly.  I don't recall it
 looking like this before.  Though
 SELECT *  FROM geography_columns
 looks fine.
 I'm trying to recall if last time I looked at this was with PgAdmin 1.10
 and now I'm running 1.10
Ticket URL: <http://trac.osgeo.org/postgis/ticket/368>
