[postgis-devel] [PostGIS] #369: shp2pg-gui the geometry column setting not sticking
PostGIS trac at osgeo.org
Sun Jan 3 14:48:31 PST 2010
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by robe):
 Its definitely buggy then.  It shouldn't do this when I click the "Import"
 button. At that point everything is set.
 Actually I had chosen geography type and it flipped the name to geog as
 you said, but
 and then when I clicked "Import" it flipped it to "the_geom"
 So I can never get a "geog" name out of this thing.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/369#comment:2>
