[postgis-devel] [PostGIS] #370: ST_CollectionExtract not Empty safe
PostGIS trac at osgeo.org
Sun Jan 3 15:19:21 PST 2010
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Old description:
> SELECT ST_CollectionExtract(foo1.the_geom, 3)
>                         FROM ((SELECT ST_GeomFromText('GEOMETRYCOLLECTION
> EMPTY',4326) As the_geom
>                         UNION ALL SELECT ST_GeomFromText('POLYGON
>                 ) As foo1
>                         LIMIT 3;
> Crashes server.
New description:
   FROM ((SELECT ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326) As
 the_geom
   UNION ALL SELECT ST_GeomFromText('POLYGON EMPTY',4326) As the_geom
 ) As foo1
 LIMIT 3;
 Crashes server.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/370#comment:1>
