[postgis-devel] [PostGIS] #227: [wktraster] Add out-db support in gdal2wktraster.py script
PostGIS trac at osgeo.org
Tue Jan 5 11:37:47 PST 2010
  Reporter:  jorgearevalo  |       Owner:  jorgearevalo
      Type:  task          |      Status:  assigned
  Priority:  high          |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster     |     Version:  trunk
Resolution:                |    Keywords:
Comment (by pracine):
 This storage method makes sence mostly when a big raster dataset is cut
 into (JPEG) tiles for a web server. The web application first grab the
 path to the file list and then forward the tiles directly from the file
 system without reading the whole tiles from the database. This is supposed
 to be faster...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/227#comment:12>
