[postgis-devel] [PostGIS] #318: 900913->4326 Transform
PostGIS trac at osgeo.org
Fri Jan 8 02:44:55 PST 2010
  Reporter:  pramsey  |       Owner:  mcayland
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.4.1
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by mcayland):
 Hi Arthur,
 If you look at the thread above, the issue is that so far only Paul can
 reproduce the error. You can help us by giving as much information about
 your system, OS, PostgreSQL version, GEOS version and PROJ version as
 possible, as well as complete test case.
 HTH,
 Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/318#comment:9>
