[postgis-devel] two questions about UsersWikiWinCompile
Paragon Corporation lr at pcorp.us
Sat Jan 9 12:18:18 PST 2010
Yah I set the prefix to a different location so can test different versions
of libxml.  Since its statically compiled into the postgis-1.5.dll anyway,
it doesn't need to go into postgres folder.
./configure works fine for me under MingW though.  It doesn't work for you.
I think both configure and ./configure work fine for me so I'm indifferent
if you want to change it.
Thanks,
Regina
  _____
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Nicklas
Avén
Sent: Saturday, January 09, 2010 2:36 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] two questions about UsersWikiWinCompile
Ok, I think I maybe see the answer to the first question myself.
It was a new approach to it in version 113 of the document. I guess it works
just as good.
/Nicklas
2010-01-09 Nicklas Avén wrote:
I was just trying to compile libxml to be able to test 1.5 aginst 8.3.
Then in UsersWikiWinCompile is it really right the line :
./configure --prefix=/c/thesrc/libxml/libxml2-2.7.6release --disable-shared
CCFLAGS=LDFLAGS="-Wl,-static" CFLAGS=-O2
shouldn't libxml be installed in the postgresinstallation?
and if so, should --prefix point to bin-folder or ?
next question
why are we writing ./configure everywhere. Yes, I know, probably I started
it, but to me it douesn't work in MinGW. I have to write just configure
without "./"
Just wanted to check before I do any changes
/Nicklas
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100109/02229604/attachment.html>
