[postgis-devel] make pdf problem for 1.5.0beta1
Devrim GÜNDÜZ devrim at gunduz.org
Sun Jan 10 00:40:20 PST 2010
I'm getting the following while trying to build pdf version of documentation:
(make pdf output):
/usr/bin/xsltproc ./xsl/postgis_aggs_mm.xml.xsl postgis.xml > postgis_aggs_mm.xml
cat postgis.xml | sed "s/@@LAST_RELEASE_VERSION@@/1.5.0b1/g" > postgis-out.xml
make -C html/image_src images
make[1]: Entering directory `/home/devrim/Fedora/postgis/devel/postgis-1.5.0b1/doc/html/image_src'
make[1]: *** No rule to make target `../../../liblwgeom/liblwgeom.a', needed by `generator'.  Stop.
make[1]: Leaving directory `/home/devrim/Fedora/postgis/devel/postgis-1.5.0b1/doc/html/image_src'
make: *** [images] Error 2
Am I missing something?
Regards,
Devrim GÜNDÜZ, RHCE
Command Prompt - http://www.CommandPrompt.com
devrim~gunduz.org, devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
http://www.gunduz.org  Twitter: http://twitter.com/devrimgunduz
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100110/a85f93a6/attachment.sig>
