[postgis-devel] [PostGIS] #311: Rename postgis.sql to postgis-1.5.sql
PostGIS trac at osgeo.org
Mon Jan 11 21:07:19 PST 2010
  Reporter:  pramsey  |       Owner:  mcayland
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by pramsey):
 A little more investigation: note that I'm testing under PgSQL 8.3. The
 Makefile.pgxs seems not to be doing the lib install because of an 'ifdef
 MODULES" test which is coming up false. For whatever reason, MODULES is
 actually not defined. And MODULE_big, which is defined, is 'postgis-1.5'
 which does not match the library we generate, which is 'libpostgis-1.5.so'
Ticket URL: <http://trac.osgeo.org/postgis/ticket/311#comment:30>
