[postgis-devel] PostGIS 1.5 regression with GEOS 3.0.3
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Tue Jan 12 02:59:20 PST 2010
Hi folks,
I'm seeing the following regression with GEOS 3.0.3 with SVN trunk, but
not with GEOS 3.1.1 or 3.2.0:
*** tickets_expected    Tue Jan 12 10:10:00 2010
--- /tmp/pgis_reg_7461/test_45_out      Tue Jan 12 10:38:45 2010
*** 1,4 ****
! #2|POLYGON((1 1,1 2,2 2,3 2,3 1,2 1,1 1))
   #11|0
   #21|SRID=31293;POINTM(6220.13 5337367.145 4566)
   t
--- 1,4 ----
! #2|POLYGON((2 2,3 2,3 1,2 1,1 1,1 2,2 2))
   #11|0
   t
The SQL that produces this appears to be:
SELECT '#2', ST_AsText(ST_Union(g)) FROM
( VALUES
('SRID=4326;MULTIPOLYGON(((1 1,1 2,2 2,2 1,1 1)))'),
('SRID=4326;MULTIPOLYGON(((2 1,3 1,3 2,2 2,2 1)))')
) AS v(g);
This looks like it is just the order that has changed rather than the
actual result. Should we consider bumping the minimum GEOS version to
3.1 for PostGIS 1.5 just to help keep things clean? As a plus, we get to
remove lots more #ifdef cruft...
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
