[postgis-devel] [PostGIS] #311: Rename postgis.sql to postgis-1.5.sql
PostGIS trac at osgeo.org
Thu Jan 14 04:30:53 PST 2010
  Reporter:  pramsey  |       Owner:  mcayland
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by robe):
 Okay my 8.3 compiles and installs fine now under mingW.  I still have an
 issue with make check that I didn't have with PostGIS 1.4 ever since that
 whole pre-install make check thing was introduced.  Could be something
 funky with my batch script for packaging though. I haven't investigated
 the error yet.
 Nicklas, have you been able to do a full make check under mingW.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/311#comment:33>
