[postgis-devel] [PostGIS] #311: Rename postgis.sql to postgis-1.5.sql
Nicklas =?utf-8?Q?Av=E9n?= nicklas.aven at jordogskog.no
Thu Jan 14 04:49:34 PST 2010
It is always little tricky to do make check, but this I think is an error I haven't seen before.In the logfile I get: psql:postgis.sql:56: ERROR:  could not access file "/c/utv/src/pg15/regress/00-regress-install/lib/postgis-1.5": No such file or directory Haven't investigated any further /Nicklas
2010-01-14 Nicklas Av�n wrote:
I will try
> > Reporter: pramsey | Owner: mcayland
> > Type: defect | Status: reopened
> > Priority: medium | Milestone: PostGIS 1.5.0
> > Component: postgis | Version: trunk
> >Resolution: | Keywords:
> >Comment (by robe):
> > Okay my 8.3 compiles and installs fine now under mingW. I still have an
> > issue with make check that I didn't have with PostGIS 1.4 ever since that
> > whole pre-install make check thing was introduced. Could be something
> > funky with my batch script for packaging though. I haven't investigated
> > the error yet.
> > Nicklas, have you been able to do a full make check under mingW.
> >Ticket URL:
> >PostGIS
> >The PostGIS Trac is used for bug, enhancement & task tracking, a user and developer wiki, and a view into the subversion code repository of PostGIS project.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100114/da079258/attachment.html>
