[postgis-devel] [PostGIS] #383: Liblwgeom not compile with POSTGIS_DEBUG_LEVEL 4
PostGIS trac at osgeo.org
Thu Jan 14 06:41:15 PST 2010
 Reporter:  colivier                        |       Owner:  colivier
     Type:  defect                          |      Status:  new
 Priority:  medium                          |   Milestone:
Component:  postgis                         |     Version:  trunk
 Keywords:  measure.c  POSTGIS_DEBUG_LEVEL  |
 ./configure
 sed -i "s/POSTGIS_DEBUG_LEVEL 0/POSTGIS_DEBUG_LEVEL 4/" postgis_config.h
 cd liblwgeom/
 make
 measures.c: In function 'lw_dist2d_ptarray_poly':
 measures.c:712: error: 'dist' undeclared (first use in this function)
 measures.c:712: error: (Each undeclared identifier is reported only once
 measures.c:712: error: for each function it appears in.)
 measures.c:712: error: 'mindist' undeclared (first use in this function)
 measures.c: In function 'lw_dist2d_ptarray_ptarray':
 measures.c:783: error: 'dist' undeclared (first use in this function)
 measures.c:784: error: 'result' undeclared (first use in this function)
 make: *** [measures.o] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/383>
