[postgis-devel] PostGIS 1.5 beta2
Kevin Neufeld kneufeld at refractions.net
Thu Jan 14 15:38:04 PST 2010
+1. 'make check' does give me one error though ...
  regress_proj. ok
  dumppoints. ok
  wmsservers. ok
  tickets. failed (diff expected obtained: /tmp/pgis_reg_1623/test_45_diff)
  regress_ogc_cover. ok
  regress_ogc_prep. ok
Run tests: 47
Failed: 1
make[1]: Leaving directory `/var/home/buildbot/workspace/src/regress'
cat /tmp/pgis_reg_1623/test_45_diff
*** tickets_expected    Thu Jan 14 14:59:08 2010
--- /tmp/pgis_reg_1623/test_45_out      Thu Jan 14 15:01:16 2010
*** 1,10 ****
   #2|POLYGON((1 1,1 2,2 2,3 2,3 1,2 1,1 1))
! #11|0
   #21|SRID=31293;POINTM(6220.13 5337367.145 4566)
   t
   ERROR:  AddGeometryColumns() - invalid SRID
   #44|t|t
! #58|POLYGON((220187.382089758 150406.434743975,220187.382089758 150506.717070259,220288.81590723
150506.717070259,220288.81590723 150406.434743975,220187.382089758 150406.434743975))
   ERROR:  geometry_to_gml2: 'CurvePolygon' geometry type not supported
   #66|CIRCULARSTRING(0 0,1 1,2 2)
   #68a|MULTIPOINT(1 3,4 5)
--- 1,10 ----
! #11|0.889477943128855
   t
   #44|t|t
! #58|POLYGON((220187.382089667 150406.434743975,220187.382089667 150506.71707029,220288.815907205
150506.71707029,220288.815907205 150406.434743975,220187.382089667 150406.434743975))
-- Kevin
Paragon Corporation wrote:
> +1 (make check still doesn't work for me, but I'd still like a beta 2)
> Thanks,
> Regina
> ________________________________________
> From: postgis-devel-bounces at postgis.refractions.net
> [postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
> [pramsey at opengeo.org]
> Sent: Thursday, January 14, 2010 3:29 PM
> To: PostGIS Development Discussion
> Subject: [postgis-devel] PostGIS 1.5 beta2
> Call for votes on releasing beta2, now that the install process seems to be
> fixed up.
> +1 !
> P
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant to
> Massachusetts law. It is intended solely for the addressee. If you received
> this in error, please contact the sender and delete the material from any
> computer.
